Can I have a price breakdown and availability for the following please:
07 11 9 932 095 - UJ washer (x10)
07 12 9 906 196 - UJ nut (x5)
32 41 1 129 986 - PAS crush washer 14id (x6)
33 52 6 779 670 - E46 top mount (pair)
51 71 1 932 996 - sideskirt grommet (x10)
51 71 1 938 940 - sideskirt clamp (x10)
51 31 1 947 248 - window rubber strip (x1)
51 13 1 947 310 - plastic rivet (x5)
11 53 1 721 172 - M42 thermo gasket (x1)
13 71 1 721 431 - M42 intake boot (x1)
13 71 1 705 064 - AFM gasket (x1)
31 33 1 139 484 - M3 lolipop bush (pair)
I also require 6 alu crush washers for the larger (16mm?) fitting for the power steering pump and rack. Item 5 in the following illustration:
http://bmwfans.info/parts/catalog/E30/T ... oil_pipes/
Thank you
Parts List
MrWhite
rust never sleeps
Cotswoldbmw
Hi There
07 11 9 932 095 - UJ washer (x10) £1.51 for 10
07 12 9 906 196 - UJ nut (x5) £4.92 for 5
32 41 1 129 986 - PAS crush washer 14id (x6) £0.91 for 6
33 52 6 779 670 - E46 top mount (pair) £38.54 for 2
51 71 1 932 996 - sideskirt grommet (x10) £1.51 for 10
51 71 1 938 940 - sideskirt clamp (x10) £8.86 for 10
51 31 1 947 248 - window rubber strip (x1) £11.40
51 13 1 947 310 - plastic rivet (x5) £12.05 for 5
11 53 1 721 172 - M42 thermo gasket (x1) £4.86
13 71 1 721 431 - M42 intake boot (x1) £24.20
13 71 1 705 064 - AFM gasket (x1) £0.37
31 33 1 139 484 - M3 lolipop bush (pair) part no supplied is for top strut mounting can you please confirm item required
32411093597 washerX6 £1.30 for 6
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 14358
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
MrWhite
Hi,
Thanks for the quick reply. I typed the wrong number for the eccentric bushes.
31 12 9 061 222 is the one I'm after. Pair please.
rust never sleeps
MrWhite
Order placed. Thanks
rust never sleeps
