Hi I have a query recently converted autobox to manual and still using the Auto ECU (Non CAT). Have an ECU from the manual car where I got the gearbox from had a sensor in the exhaust ( I guess due to a CAT fiited) can I use this ECU to repalce the Auto ECU without having the CAT?
Any advice greatly appreicated
Chas
M40 1.6 with 1.8 ECU
All ECUs are suitable for use with or without a cat, although some late AFMs don't have a CO adjuster, so can't be used without a lambda sensor.
If you've removed a cat from a M40 engined car, there are two white/black wires under the bulkhead wiring cover, which have to be plugged together to connect up the CO pot on the air meter.
Ch4ni
Hi thank you for your update I did not remove the CAT (the cat car does not have lambda sensor) I have a ECU from a car that had a lambda sensor and I would like to fit this ECU into my car and would like to know how to do this. Are you able to show me a picture of where the black/white wires are located and ow to connect them together?
Chas
Chas
If you haven't removed a cat (+ lambda sensor) from the car in question, then no wiring changes are needed.
Why are you trying to connect a 1.8 ECU to a 1.6 engine?
Ch4ni
I am trying to understand if there is difference in the ECU between Auto car and a Manual car are there any differences?
I did not mention 1.8 ECU to 1.6 where did you get this info from?
Well, this is the title of the thread: "M40 1.6 with 1.8 ECU"!Ch4ni wrote: I did not mention 1.8 ECU to 1.6 where did you get this info from?
No difference between an auto and a manual ECU.
Ch4ni
Silly me, you reminded me I wanted to ask is there was a difference between the 1.8 ECU and 1.6 ECU this is to decide if to keep it as spare.
