m30 engine ecu
ammar786
Post Mon May 23, 2011 9:55 am
hi guys i have finally finished my project just on the last stages
but i wanted to knw if i have to change the ecu
as i have used all the standard m20 engine loom which i have addapted to fit
the car starts and runs but i didnt knw weather the map for the 2.5 and 3.5 is different
any help would be appretiated
thanks
zaust
Zone day release
Post Mon May 23, 2011 12:43 pm
you need the m30 map or you will not have the correct values.
M30 Tech 1 Touring on gas.
Post Mon May 23, 2011 12:44 pm
I can supply an uprated or standard M30B35 chip if you need one.
No need to change the ECU - any later six-pot one will work, although the correct one is the 0 261 200 179.
ammar786
Post Mon May 23, 2011 2:16 pm
hi mate
can you pm me the details for the chip
thanks
simainman
Post Mon Oct 10, 2011 10:38 pm
Speedtouch wrote:I can supply an uprated or standard M30B35 chip if you need one.
would it make any difference if the ecu from the m30 engine was from a auto?
i am planning on using my 1990 facelift m20 manual loom along with a m30 ecu on my conversion,the m30 engine i have was from a 1989 e32 auto so could i still use that ecu? or shall i get one from a manual as i have read somewhere that it also controls the auto transmission is that correct?
any advise would be great,
thanks
simainman.
leeparkes
Post Mon Oct 10, 2011 10:48 pm
Auto ECU can be used with no issue's.
zaust
Zone day release
Post Tue Oct 11, 2011 9:38 am
If you have access to a b35 loom use the whole thing. Saves a lot of time and is an easy job.
simainman
Post Tue Oct 11, 2011 6:25 pm
zaust wrote:If you have access to a b35 loom use the whole thing. Saves a lot of time and is an easy job.
i have the whole e32 m30 engine loom but its from a auto,i read here http://www.e30.de/335i/16.htm that if i had an auto loom i may as well source a manual loom as many cables run through it to operate the auto :cry: so i was going to use the m20 loom to keep cost down and save time stripping out all the cables i don't need.
thanks
si.
