Panasonic head unit losing all settings after ignition off
PeteE30Tourer
Post Fri May 20, 2011 7:40 am
Hi - just as the title says really. I just replaced an old Clarion head in my cab with a Panasonic one that I bought off ebay. Works fine, except all the presets and balance/fader settings are lost when I remove the ignition key. I assume there should be a permanent-live feed to the radio to keep the settings, but does anyone know which colour this wire should be and which pin in the connector it goes to?
The adapter cable i'm using takes the single connector at the back of the Panasonic to two white connectors - one eight way for the 4 speakers, and another 8-way with only about 5 wires connected. Both of these then connect to the car's loom. Is this a standard set-up?
Back behind an M20, but now I can hear it better.
manse73
Post Fri May 20, 2011 10:52 pm
swap the permant live and ignition live had this problem with a sony head unit
bruv chariots rule
PeteE30Tourer
Post Fri May 20, 2011 11:00 pm
Thanks for this - any idea which colour wires these are, or what pins they go to? Could sort it with a multimeter I guess.
What model Panasonic is it.
Normally have, Red, blue, yellow, orange and green iirc.
bigwinn
Post Fri May 20, 2011 11:04 pm
yellow is usual standby power
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
