Aggghhh, just broke the starter terminal off....
Post Tue May 17, 2011 9:06 pm
The plastic body snapped like a carrot :(
Cant quite see whats what as its under a 24v inlet etc, there is nothing connecting the two parts together, if I hold the broken part against the solenoid is it likely to work the starter? Auto gearbox so no bump start
bimanut
Post Tue May 17, 2011 9:49 pm
As long as the elecrtical conduter is still intact inside the broken lug and there is still another part of the conductor is showing i cant see why it wouldnt work,
But i`d expect a few sparks and possible shock 8O
Did something simmilar myself and where the plastic bit had broke off it left a little metal dome thing showing where i could make a connection.
Worth a go a mate :)
