M30 twin turbo
dannymac
Post Tue May 17, 2011 2:49 am
Hi guys,just signed up,was a member before,cant remember my old username/password lol :mad: - was a long time ago...cant believe how many 335s around now..when i started toying with the build,there were only afew done.All good ,means theres alot more info out there:)
Ok afew Q's..anyone done a twin turbo m30 ?,,who does/does anyone do forged pistons for the m30?,,on the turbo conversions you guys are running,is it thicker gaskets or a spacer between the block and gasket youre using to lower the compression??,, has anyone lowered the comp by pocketing the pistons??,,manifold....ive read afew saying custom is the way to go..but as far as having a basis to work with,what ss manifold would be best to start to modify,,one for an m20 or the later pair from an e36 328,which are available on Fleabay in turbo applications?(I have a tigwelder,cutting/bending gear),,and finally -clutch/flywheel,,uprated clutches are available or will it have to be custom?Is the later 735 flywheel easy to lighten,its not dual mass or..?,Ive never seen mine yet...
All the above applies to m30 motors from either an 735i auto and a manual car(if theres any diferences to their internals)as I have both here as runners ,theyre 1992 reg.Loadsa questions there lol,look forward to your opinions/replies.
Kos
Post Tue May 17, 2011 2:53 am
wait for gunni to post up
but if you want a proper low comp engine, i have an alpina bi turbo engine for sale
robbo86
Post Tue May 17, 2011 10:00 am
Driftboy would be your man... His was only a single turbo m30 but still bloody rapid, with decent set of anchors to match. Took me for a spin in it once, massive grin factor!
Gunni
Post Tue May 17, 2011 2:56 pm
dannymac wrote:Hi guys,just signed up,was a member before,cant remember my old username/password lol :mad: - was a long time ago...cant believe how many 335s around now..when i started toying with the build,there were only afew done.All good ,means theres alot more info out there:)
Before any answers can be given what is your power goal?
from your post there is nothing that suggest a potential power goal, power delivery or anything.
Gunni
@ 2012 VEMS group buy !!
dannymac
Post Tue May 17, 2011 4:54 pm
Dont think they need that,its not very technical questions,"yes ,no,heres a link" answers will do.There arent any goals yet,obviously the bigger the better as far as dyno numbers go.Other than that,its building a strong base for future tuning without the need for tearing it down again very soon,its still in the planning stages.I havent been near the bmw in 8 years or more,so kinda rusty over what i leanrned before about the m30 and what was availaable,Im sure theres alot more around now than back then.I have sucessfully turbo'ed other non factory turbo engines before.Just dont know much about whats available for these beemer blocks yet.,hence the questions :)
Post Tue May 17, 2011 5:02 pm
The M30 can be boosted to about 400hp with standard internals, Gunni will confirm this, but anything after that you will need to spend big money.
Look for "StaleyTurbo" post on his M30 turbo
dannymac
Post Tue May 17, 2011 5:06 pm
lol.thanks,ill look there.
leeparkes
Post Tue May 17, 2011 7:47 pm
Rav335uk wrote:The M30 can be boosted to about 400hp with standard internals,
I thought it was 550hp on standard internals.
Kos
Post Tue May 17, 2011 9:19 pm
i think thats pushing it a bit, but if true it makes you wonder how much power could be squeezed of of the alpinas
That's to be on the safe side, you need to have a very good engine for 500hp I would presume.
leeparkes
Post Tue May 17, 2011 9:25 pm
You posted the link Rav :D 580hp 600ftlb
http://www.e30zone.net/modules.php?name ... c&t=179900
Post Tue May 17, 2011 9:33 pm
leeparkes wrote:You posted the link Rav :D 580hp 600ftlb
Ha ha , so I did, but really, I think either a rebuild with standard parts should see it do that.
Kos, what engine you got for sale? E34
Kos
Post Tue May 17, 2011 9:37 pm
e34 alpina bi turbo block with cranck/rods/pistons/sump
came from a car phil crouch at CPC
i was going to use it in my M3 but not any more.
Post Tue May 17, 2011 9:46 pm
Where's the head?
Gunni
Post Tue May 17, 2011 10:07 pm
dannymac wrote:Dont think they need that,its not very technical questions,"yes ,no,heres a link" answers will do.There arent any goals yet,obviously the bigger the better as far as dyno numbers go.Other than that,its building a strong base for future tuning without the need for tearing it down again very soon,its still in the planning stages.I havent been near the bmw in 8 years or more,so kinda rusty over what i leanrned before about the m30 and what was availaable,Im sure theres alot more around now than back then.I have sucessfully turbo'ed other non factory turbo engines before.Just dont know much about whats available for these beemer blocks yet.,hence the questions :)
I´d not go much past 350hp on a 100% standard engine
500-550hp with ARP studs.
600-650hp with a cam and ARP studs,
all stock bottom end setups.
Gunni
Post Tue May 17, 2011 10:14 pm
What H/G would you recommend?
Gunni
Post Wed May 18, 2011 8:40 am
Stock, I´m assuming low compression M30B35 btw
Gunni
chu346
Post Wed May 18, 2011 10:38 am
But what about the drivetrain?
dannymac
Post Wed May 18, 2011 11:10 am
I pulled my finger out and did my own homework...Ive found a supplier of forged pistons the USA,they also do rods,debateable if theyre nesessary?i tried ARP directly,had no joy,but then found a place in Germany selling the bolts.im thinking of wire ringing the block and using a steel gasket to achive a suitable comp ratio.Im just not sure is it twin or a single turb im going for(the extra hassle for squeezing in twins worth it,presuming theyll only fit under than top mounted).Gonna measure up the manifold on my e36 against the m30 one before i purchase one for a cut n shut.
Gunni
Post Wed May 18, 2011 5:26 pm
chu346 wrote:But what about the drivetrain?
Clutch
and find half shafts if you plan on something like 25-30psi boost
Gunni
chu346
Post Wed May 18, 2011 6:17 pm
Propshaft ok?
Gunni
Post Wed May 18, 2011 9:26 pm
Yea as long as you don´t launch it with slicks often at more then 20psi from dead stop.
Gunni
Kos
Post Wed May 18, 2011 11:09 pm
Rav335uk wrote:Where's the head?
warped so binned.
a stock m30 head and cam is fine.
