Interior Dash Lighting
browny
Post Fri Oct 14, 2005 5:02 am
Hello to you all. Just wondering if there is anything that can be done to make the instrument lighting brighter (yes I know about the dimming knob). I have installed LED's for the blinkers, park brake etc... works great but the two big ones for dash don't reflect well (when using LED's) I was just wondering if there is any other solutions to get some extra brightness??
steedymorgan
Post Fri Oct 14, 2005 6:02 am
what voltage leds are you using mate, if there 3v and your using a resister to cute voltage, try a low resistance as long as you stay over 425 ohm's it wont blod led. but if your using 12v leds then just go for a lighter one do you know MCD they are?
i'm just doing my heater con's and headlight dippers at moment in blue, window swicth's are next :cool:
325ise good but needs more power lol
how do i get my pics on here lol!!!!!
http://i15.photobucket.com/albums/a383/ ... MW325I.jpg
browny
Post Sat Oct 15, 2005 12:48 pm
I am using 12v LEDs and I have not had satisfaction with the light they emit. Very dim. Also put a smaller 5mm 12v in the clock to see how that went. Not as bright as a standard bulb. I bought premade LEDs from ledshoponline.com
As for MCD..... what is that??
