has any1 hear of or used ding king/pops a dent?
have couple of small to large dents on doors boot ect and some1 said to get either of the 2 products mentioned above its a paintless dent removal tool which uses special strong glue to pull dents without damaging paint has anyone used this method or bought the products mentioned above?ther around 20 pounds im a bit optimistic??
dont forget- different dents/dings in different places and sizes made by different ways- require different ways to get them out -some can be pulled, some need rods and pushed/massaged out in a certain way, if you just buy something like that yourself and start gluing them and pulling them out- without really knowing what your doing, you could very well make them worse and end up worse than when you started, and if its been wrongly attempted- chances are that it will then need to be fillered and painted to be fixed, as a dent removal expert wont be able to sort a dent thats been wrongly attempted to fix,(i think) also if using such methods- the paint MUST be factory and strong, or it will pull the glued paind off
have you ever watched a dent expert work ? - theres so much to it
- brettE30cab
I had a load of dents and dings taken out of my car two weeks back, very pleased with the result , ice got to say though it did look piss easy!! But it was only £65 so it doesn't make sense to try yourself for £20 surely.
