Thanks Brian Mooore
Martin123
Thu May 12, 2011 9:30 pm
The dash lights on my 325 touring failed but after searching on this forum I saw Brians advice to earth the brown ashtray cable: and yes the lights came on! Cheers Brian, I guess this means the headlamp switch is faulty so I'll pull it out and have a play with it. Any advice on which colour cable I should be looking for?
Thu May 12, 2011 9:33 pm
Brown/white at the headlamp switch, the same as at the ashtray.
If you're happy to live without the dimmer function, just earth the brown/white wire for a permanent fix.
Martin123
Thu May 12, 2011 10:19 pm
Thanks Brian, I'll check the switch then depending on that I'll try the earthing option.
snakebrain
Fri May 13, 2011 3:27 am
Brian Moore deserves more than thanks - he deserves a bloody medal! :D
BMW_E30vert
Fri May 13, 2011 10:19 pm
^^ +1
did the black and red wire mod today and my central locking is working now after 5months of being dead :D
