fuel tank, pump and swirt pot positions
Driftben
Post Sun Apr 24, 2011 11:36 am
im going for a boot mounted (where the spare wheel was) fuel tank setup with external pumps.
questions is what sort of setup are you guys running and at what positions in the boot is the setup.
thanks
ben
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
djs325
Post Sun Apr 24, 2011 2:44 pm
We're now running the ATL 12 US Gallon Well Cell with the built in surge tank and high pressure pump. Comes as an all in one unit you just need to do plumbing and wiring. Not cheap but much easier, just use a single in-line external filter.
Driftben wrote:im going for a boot mounted (where the spare wheel was) fuel tank setup with external pumps.
thanks
ben
E30racing.com.au - Like Production BMW Cup, but upside down!
e21Jason
Post Sun Apr 24, 2011 2:53 pm
0n the e21fuel tank in the spare well, pumps filters, swirl pot under the rear seat where the tank used to be, battery on other side. tank cut in half so the bottom section becomes a cover
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Driftben
Post Mon Apr 25, 2011 6:28 pm
thanks for your replies guys, could i trouble you both for some pictures?
i was thinking along the lines of a fuel tank in the spare wheel well with a in tank pump feeding the swirl pot then a larger pump feeding the fuel rail with inline filters.
have you guys ran the fuel lines in the cab or underneath the car?
thankyou
ben
6pot wilwoods front
4pot Porsche rear
winx
Post Mon Apr 25, 2011 11:19 pm
I have been looking into this for my touring. I was going to use a pre facelift lift pump in the 63l tank to feed a swirl pot in the spare wheel well. Then use a decent high pressure pump to feed the fuel rail...
Having had a look the feed to the swirl pot could probably go either underneath the car or inside. Inside looks to be the easier option
