Ignition Control module and distributor
srmalek
Post Tue Apr 12, 2011 2:09 pm
Hi how to check whether my Ignition Control module and distributor is working on my 323i , because there's no spark on the spark plug,
m8782538
Post Tue Apr 12, 2011 2:44 pm
check output from the coil then, multimeter, not sure what it should read though.
srmalek
Post Tue Apr 12, 2011 3:30 pm
Ok thanks, btw will the current run thru the coil before going to the distributor ? Sorry I'm new in this engine thingy
m8782538
Post Tue Apr 12, 2011 3:32 pm
battery, coil, dizzy, plugs.
nothing at the coil would indicate you need a new one. brianmooore is the best person to ask.
srmalek
Post Tue Apr 12, 2011 3:41 pm
Ok how about the igniter control module , what,s The function of it,
m8782538
Post Tue Apr 12, 2011 3:45 pm
timing for the spark plugs make sure they fire in the correct order, helps (as far i know anyway) along with the dizzy.
best pm brianmoooore, he's pure genius with E30's.
srmalek
Post Tue Apr 12, 2011 3:54 pm
Cheers mate, btw brianmoooreee if u read this mate pls help me out heheh thanks
Post Tue Apr 12, 2011 8:46 pm
Sorry, I'm not familiar with this really old stuff at all, especially when it's not in front of me.
willnz is more likely to be able to help.
