aircon hose problem
dman
Tue Oct 11, 2005 10:56 am
Hi All
Ive just had my aircon gas conversion done & regassed, but the gas
leaks out again!. Tuner says that i need a new hose, one that runs
from the compressor to the condensor.
Problem is that he/we do not have a part number ?
any help/suggestions, pleeeeeeeeeeeeaze
spoon320
Tue Oct 11, 2005 11:38 am
I would try www.realoem.com first, but i'm sure someone will squirrel it out for you shortly
Edit - These might help:
PRESSURE HOSE ASSY COMPRESSOR-CONDENSER 1 from 06/1983 64531372618
03 PRESSURE HOSE ASSY COMPRESSOR-CONDENSER 1 from 06/1983 to 09/1985 64531373589
Realy need to know year and model
Danstable
Tue Oct 11, 2005 1:41 pm
I'm afraid I don't have an answer for you......but I would be interested if someone could give me some pointers on the best way to locate a leak. My '91 Tourer lost all its gas within 10 minutes so I need to replace something, the question is, what?!
Templ8e30
Tue Oct 11, 2005 7:20 pm
Hi Dan, how's it hanging ?.
If you save some more Ԛ£ and take the beast to an air-con specialist they can find the leak by several different means, one is regassing and introducing a dye which leaves a purple stain at the leak or they regas it and use an electronic 'sniffer' to find the leaking gas.
The M30 afm is on by the way, just needs a bit more tweeking. It's actually giving me more MPG at the mo :mad:
Sorry gents :offtopic:
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Danstable
Wed Oct 12, 2005 10:00 am
Thanks for the advice Iain, I have no dollar at the mo so it will have to wait......not like I really need aircon at the mo anyway!
Glad to hear the AFM is doing something good, could do with it back if it reduces fuel consumption!
