lowering a e32 730i
steviebmw
Post Fri Apr 08, 2011 4:07 pm
my mate has asked me to cut his springs on his e32 730i. he wants it lowered. i have done fords in the past but not a bmw. if i cut the springs how many coils should i cut and what would i charge him as he all ways come to me with cars that need work :D
rancido64
Post Fri Apr 08, 2011 4:14 pm
Prepare to be slagged for cutting springs winkeye
steviebmw
Post Fri Apr 08, 2011 4:15 pm
I HAVE NOT SAID ANY THING TO HIM YET
Post Fri Apr 08, 2011 4:19 pm
Charge him £300 for an Eibach Pro Kit ( will cost you about £250 ) Plus say £200 for labour.
Cutting springs is for driftc0cks and tw@ts.
steviebmw
Post Fri Apr 08, 2011 4:20 pm
OK
Andyboy
Alpina Colada
Post Fri Apr 08, 2011 6:33 pm
Cutting one coil (and one only) from E30 front springs works well. But you can'y cut E34/E32 springs because the bottom coil is a smaller diameter than the next one up - once cut, the springs will not sit properly in the lower spring cups - cue a disaster when they dislodge and rip the tyre sidewall out. You can cut a coil or two from the rears if that's your thing.
To lower the front, a pair of E34 520i springs drops it about 40mm. Doing it properly involves a set of Eibach springs.
steviebmw
Post Fri Apr 08, 2011 7:28 pm
ok i will tell him is the top of the front spring different
Post Sat Apr 09, 2011 12:11 am
I have a set of H7s Hartge lowering springs/Bilsteins I may sell ?
steviebmw
Post Sat Apr 09, 2011 12:14 am
how much
rob0r
Post Mon Apr 11, 2011 3:14 pm
I coilover converted my old E32 735i
Front: 2.5" compbrake conversion kit, 2.5" ID springs, normal shocks
Rear: E28 Koni sport shocks, 2.25" compbrake conversion kit, 2.25" ID springs
It turned out really well, but doing this is fairly involved and you need some welding/fabrication skills to do it right.
Front coilover converted struts:
Post Mon Apr 11, 2011 3:16 pm
rob0r wrote:I coilover converted my old E32 735i
Don't give him ideas.. :eek: :eek:
