I am having a few issues with my car, its running rough and very hesitant between 2000 - 3000 rpm, and some times on start up it pops and bangs down the exhaust.
I've tried new maf, icv, plus, coils, injectors ect
Does anyone have any suggestions on what to try next; it’s not coming up with any fault codes.
B30 Running rough
Gunni
Sounds like a vacuum / unmetered air leak .
what happens if you disconnect the MAF ?
Peet
Have checked all rubber pipes and they all seem ok, have tried sprayin leak detector stuff and it didn't find ewt but worth another check.
When i disconect the maf it starts to run uneven on tick over
penton08
Seems strange, it ran like a watch in its old home
I believe the early cars need some sort of speed sensor signal wiring up to the ecu, have you done this? Have you tried leaving the battery off for a while after changing things?
Peet
Does seem a bit of a odd one, its bafflin people up here. Just little teethin problems, all part of havin moddifed cars int it.
Yeah had sorted the speed sensor n rev counter plug into the right place when i fitted the facelift 2.5 engine n ecu last year.
Nah not left it disconected will give that a try tonight and see if its any different tomorrow.
Peet
Changed the blue temp sensor now and reset the ecu (still wasn't any codes coming up), its still playing up and drinking its fuel
just done a run on the motorway and keeping it to 60 - 70 its done 20mpg and all the plugs are black, will keep tinkering with it for now
any suggestions would be great as i am running out of things to try and replace now
Sounds like its running in limp? Lambdas ok?
Peet
is there anyway of knowing if its in limp? and how to get it out of it?
the lambas are next on the list to look at, can they be tested or is it just a case or buy new ones and try them
Peet
Well its fully dead now so hopefully its nothin major
Was running but started to miss then stopped and now just turns over but won't fire
AA are coming to take it home for me soon
Peet
well eventually managed to get it running again, least it means i can get back on with trying to find why its running rough and drinking silly amounts of fuel
