hi,
Just a quick one,
The engine oil light has shown up on the check panel, what could be the reason for this?
Never showed up before, oil was changed in September 2010, though car has been sitting over winter (5month) could that cause an issue??
325i Cab if it helps...
Check panel Engine Oil light is on ????
12345kevin
Presumably you have checked the oil level and topped up if required ?
KSP_E30
Yep oil level checked out just fine.
- E30 Zone Meets/Events Team
Faulty sensor
KSP_E30
Might be, an expensive fix ?
dobbie82
- Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
I think mine came on when my fan had no shroud on it and the fan went through the wire
Easy fix
Most sensors are reasonably priced even from BMW
Easy fix
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
KSP_E30
Where's the location of this sensor ? Sump?
dobbie82
the oil pressure switch is somewhere about the front of the engine.. as the wire goes in somehere about the fan.. (sorry to be vauge but I am no mechanic) But if its the wire thats snapped, you will be able to see it.
The oil level sensor is about £100
so if its that, then you need to be looking 2nd hand! but anyways its number 7, click it to enlarge.
