dme/ecu question
e30325itourer
are these interchangeable ie not coded to the engine which is a 328 m52 ?
THE ULTIMATE DRIVING MACHINE
e30325itourer
cheers danDanThe wrote:ECU/EWS and key chip are a package, if you mix them up the ECU wont allow the engine to start
does this package fail often?
best way to fix it if possible.
- Contact:
The module and key chip are produced to work together, they are then coded to the ECU. If you have a matching chip and EWS you can have them re-coded to a different ECU, if you know someone with the right equipment
