headliner cleaning?
cro320
Post Mon Mar 14, 2011 5:25 pm
My headliner is tight and doesn't falling off but is yellow from cigar smoke...i really hate it.
So far I tried loads of cleaners but they didn't work.
Anyone have solution?
beemerbird
Post Mon Mar 14, 2011 7:09 pm
One of the best things I know for removing nicotine stains is Sugar Soap. It's available in the UK for cleaning old paintwork prior to re-painting.
beemerbird
Post Mon Mar 14, 2011 7:12 pm
http://www.ehow.co.uk/how_5896459_use-s ... aning.html
The thing is to get the stuff off well after using it.
cro320
Post Thu Mar 17, 2011 6:32 pm
thanks!
is there any other product or I should leave it yellow as it is
m8782538
Post Fri Mar 18, 2011 8:50 am
upholstry foam cleaner and a still brush. Will need some elbow grease and a couple of attempts but it should come off, then just a wipe over with you usual interior detail spray and you should be sorted.
I would give the sugar soap a try first as sugar soap is so cheap. Simoniz foaming upholstry cleaner is pretty good and not expensive either.
DaveD
E30Zone Wiki Specialist
Post Fri Mar 18, 2011 9:54 am
if its that bad the upholstery must have soaked some up too.... i used one of those carpet cleaning machines with an upholstery attachment and it brought the whole car up like new....you would be amazed how much dirt came out of this car
m8782538
Post Fri Mar 18, 2011 11:44 am
luckily i have a vax cleaner (one of the original bright orange ones) but inside the car is actually pretty clean, i was supprised. Maybe give it a clean in the summer when it will dry that little bit quicker.
melliott
Post Tue Apr 12, 2011 10:01 am
Hi
If you have got a steam cleaner with the attatchments put a micro fibre cloth on, put some flash multi purpose (a very small amount) in the steam cleaner when filling with water
