OBC and Alarm conflict?
tourer-dan
Post Sat Oct 08, 2005 7:17 pm
Just wiring in an OBC on my car today and the white connector with the 2 green wires which plugs in behind the glove box had nowhere to go. The female plug on the car's loom has a plug already in it from the alarm.
What is the connector for? and does anyone else have a BMW alarm and OBC? I'm sure cars must have left the factory with both options so I don't want to just splice the connectors all together.
smithy318i
Post Sat Oct 08, 2005 8:13 pm
Fuel pump cut off.
Useless unless you plan on using the OBC code function. (but then why would you if you have an alarm)
tourer-dan
Post Sat Oct 08, 2005 8:31 pm
Superb, I'll plug the alarm back in!!!
thanks mate!
gcorky
Boost Junkie
Post Sat Oct 08, 2005 9:36 pm
i have the bm alarm and obc ,code function only isolates my obc till correct code entered,does not immobilise car due to alarm system being wired in :x
