M50 Radiator - Questions
oldroydsr4
Post Fri Mar 11, 2011 10:13 pm
Evening Gents,
I have what I believe is the e34 m50 rad on my touring (the one with the header tank installed in the end). The header tank is leaking at the o-ring at the bottom, I've bought a replacement but can't get the old one out, has any one got any tips.
Also I'm thinking of replacing the rad, is it worth buying a pattern part or is behr the only way to go?
Is there any other BMW rad that will fit straight in that will be better for some track use?
I know lots of random questions, but the radiator looks alittle tired so might hit a few birds with one stone.
Post Fri Mar 11, 2011 10:15 pm
M52 328i rad will do the job from an aircon equipped car.
Nissens are a decent enough aftermarket make
Sjoerd320i
Post Sun Mar 13, 2011 11:42 am
e36 325i aircon rad wil also drop straight in.
Post Sun Mar 13, 2011 12:43 pm
Aircon spec rad is the minimum for track use
oldroydsr4
Post Sun Mar 13, 2011 8:00 pm
Dan what radiator are you running on your track car?
Post Sun Mar 13, 2011 9:50 pm
S50 rad and oil cooler now, much much better, although I think an oil cooler on its own without the bigger rad would make a big difference anyway
