m43 headgasket????
Andy325i
Post Tue Feb 22, 2011 11:50 pm
Went to look at an E36 compact tonight for a friend.
Symtoms are: looses the water, electric fan doesn't come on (No viscous fitted?) Pipes "seem" to become hard.
I know the plastic part that goes between the head and the top hose fail, so had already mentioned that to her. Let it warm up and saw a drip from that area.
Part 7 here:
Litterally touched the top hose and WOOOOOOOOOOOOOOOSSSSSSSSSSSSHHHHHHHHHHH!!!!!!!
Boiling water EVERYWHERE! And it was PROPPER boiling inside the head. This was after fast idle for 5 mins after starting from cold.
The end of the plastic bit was broken off in the end of the top hose, dispite a garage apparently having fixed it not long ago.
Had the head gasket done about 6 months ago. Don't know if the head was skimmed, but suspect not knowing the fools that did it.
Top hose gets hot, bottom hose stone cold.
No water in the oil
Has 180k miles on it.
I'm thinking:
a)if she is VERY lucky its just the above part (7) that was loosing water
b)Thermostat is stuck shut
c)Radiator is blocked (unlikely)
d)Head gasket is gone and the pressure caused part 7 to break due to the pressure
or
e)Part 7 has failed through age and now the head gasket has gone due to driving with little/ no water
Do M43 engines suffer from head gaskets?
Thoughts please :)
What would you do next (Other than fit an M52! :D)
Many thanx
Andy
Ziggy
Post Wed Feb 23, 2011 9:17 am
How's the water pump? M43s do suffer from HG issues, but they're about as easy as a HG can be... & at least it's not snowing now unlike when mine went!
Why no viscous? Has it still got the rad shroud in place?
Andyboy
Alpina Colada
Post Wed Feb 23, 2011 9:33 am
It might have aircon - a/c equipped 316i and 318i's have a leccy fan and not a viscous.
Most M43's are ripe for a head gasket now.
Ziggy
Post Wed Feb 23, 2011 9:49 am
Ah - mine's a rubbishy dealer-fit system so it's got both...
darkchild
Post Wed Feb 23, 2011 9:57 am
M43s love a head gasket - they typically go at around 100K. As Ziggy said though they're a simple fix on these. The M43 is a lovely thing to work on.
TheHeap
Post Wed Feb 23, 2011 2:09 pm
M43? is this the 1.9 Is engine?
darkchild
Post Thu Feb 24, 2011 7:18 am
TheHeap wrote:M43? is this the 1.9 Is engine?
Nope, that is the M44.
M43 is the 8v 1.6, 1.8 & 1.9 found in the E34 518i, E36 316i and 318i and early (pre 2001 iirc) E46 318i.
TheHeap
Post Thu Feb 24, 2011 11:53 am
Ah, my friend has a W reg 318ci with this engine. his top hose retracts, as in shrinks as if it is being sucked from inside. feck knows why
