i know it basically bolts straight up but what do i have to do with the prop coupling 328 being 4 bolt and the m3 being 6 how do you change that flange or what do i do to make it fit??
im pretty desperate to get this done asap need the car for saturday any help would be great
cheers
Si.
e36 help M3 diff swap onto 328
Andy325i
You need an Evo prop to fit the Evo diff. AFAIK the rear flange isn't interchangable.
The Evo prop will fit at the gearbox as the M52, M3 and M3 Evo all use the same size rubber donut between the gearbox and front of the prop.
Ebay is your best bet, Evo props normally go for £50 to £100
Andy
Andy
beardymat
- Location: sheffield, city of steel, and rust apparently
you could also try sending glenn on here a pm as he breaks evo`s. dead reliable too.
M-Sport
Isn't the evo rear subframe needed to fit the m3 evo diff on a 328
i think you need the 3.0l m3 diff as it will fit your existing rear subframe but you will need to change flange
Try e36coupe.forum im sure there's a link somewhere on there explaining exactly what you will need.
si-
ir not an evo diff its a 3.0 non evo, how do you change that flange???
