Engine mounts & Brake servo hose
virdi325i
Post Fri Feb 18, 2011 3:56 pm
Hi can anyone help, I have M3 with S50 engine. (Brought the car with conversion already done)
I'm getting the engine mounts changed, but having big probs finding the correct ones. They are the cotton reel style (circular tube like) rough diameter 60mm and the thickness of the mount is 30-40mm (they do not have a offset - like the e28 M5)
Can anyone help where I can get these??
Secondly I can't get hold of a flexible brake servo hose, looking for a length 650mm plus again any ideas where I can get this from?
telski789
Post Fri Feb 18, 2011 4:23 pm
ask whipsey mate...he has quite a lot of servo hose...
virdi325i
Post Fri Feb 18, 2011 5:22 pm
Many thanks, I have pm him
About these mounts.... I have read on a previous thread that akgmotorsport do mounts.... however not sure if the screws are straight through or on a offset?
MrBenn
Post Fri Feb 18, 2011 6:47 pm
The AKG mounts are designed to hold the m50/s50 in the e30 with the offset designed into the mounts so they aren't twisted.
http://www.akgmotorsport.com/catalog/ca ... M50%20Swap
The servo hose can be bought from any motor factors by the foot or on ebay.
vanos
Post Fri Feb 18, 2011 8:22 pm
I've bought these engine mounts
http://www.revshift.com/shop/index.php? ... oductId=67
instead to the AKG mounts because they do the same but are a bit cheaper. :cool:
Post Fri Feb 18, 2011 9:02 pm
Ive seen those before, they dont look like they have the correct angle
