most of the paint on my car is in pretty good cond but the passenger door is really dull compared to the rest of the car and there are a couple of patches where its really faded (turning white).
Is there anything i can buy or do to try and get the colour and shine back apart from having the panel resprayed.
fading paint
Richy325iTouring
- Contact:
g3 and mop the car
the give it a dam good polish
i take it it is metallic
id suggest that panel may well have been painted at some time
try a product called p21s paint cleanser
this will remove any oxidised paint/laquer
this may well do the job
if it improves things but not entirely then id suggest using a stronger product such as g3 as richy suggests
but apply and remove both by hand if you havent used a mop/orbital before as incorrect use can cause "burn"
always use the mildest product first and work up to the most abrasive until you achieve what you are looking for
hth
john
hth
john
