m20b25 compression test
bluff467
Thu Jan 27, 2011 8:56 pm
Doing a compression test on my 1991 325i, haven't done one of these before, any advice, (dos and donts)
Chris
Life is short so enjoy it while it lasts. Buy an E30!
bluff467
Fri Jan 28, 2011 8:15 pm
[quote="bluff467"]Doing a compression test on my 1991 325i, haven't done one of these before, any advice, (dos and donts)
Anyways did the cmpression test but I'm a bit confused, (doesn't take much) I got readings of 168 to 175 psi, but thought that they should've read between 142 & 150 psi. Iused a snap-on compression tester. Any advice?
e301988325i
Fri Jan 28, 2011 9:54 pm
Did you have the throttle fully open? The main interest with cranking the car over and doing a compression test is a % comparison between cylinders should be <5% difference.
A leak down test will give you much more information, if you are having problems, and haven't found anything wrong.
I said:
e30topless said:
lock the wife in there
