Exhaust paint
Post Tue Jan 25, 2011 9:36 pm
Can anyone recommend a good high temp exhaust paint?
I have decided to put a standard system back on my car and have bought an unrusty genuine system that i want to stop from going rusty.
csl
Post Wed Jan 26, 2011 2:05 am
bss325i wrote:Can anyone recommend a good high temp exhaust paint?
I have decided to put a standard system back on my car and have bought an unrusty genuine system that i want to to from going rusty.
I used the "VHT"brand paint and it seems to have lasted quite well considering its now been on the (original) system about 3+ years.Could probably do with a re-application now to the front sections but the rear sections are still excellent. In all fairness,i dont use the car in bad weather and only do a small mileage(about 2k ish)per year, though i did spend a fair amount of time on the preparation of the metal. 8)
Post Wed Jan 26, 2011 7:59 pm
What sort of prep did you do? Did you prime it in any way or just use the VHT?
Kos
Post Wed Jan 26, 2011 8:42 pm
powder coat :?:
oguz327
Captain Armco
Captain Armco
Post Wed Jan 26, 2011 9:53 pm
How come your going back to standard Barry? Are you keeping the BTB on there or changing the whole lot?
Dan320is
Post Wed Jan 26, 2011 9:59 pm
Kos wrote:powder coat :?:
There must be some type of heat resistant powder coat? It would be a more durable finish.
Post Wed Jan 26, 2011 10:07 pm
oguz327 wrote:How come your going back to standard Barry? Are you keeping the BTB on there or changing the whole lot?
The BTB is staying Oz but the rest is going in favour of a genuine BMW system.
I'm going back to standard as its more in keeping with the theme of the car, ie OEM.
oguz327
Captain Armco
Captain Armco
Post Wed Jan 26, 2011 11:02 pm
Sounds like a good plan, you never know, might be a few more ponys to be had by going back to the standard system.
Post Wed Jan 26, 2011 11:10 pm
Will be interesting to see.
Kos
Post Wed Jan 26, 2011 11:24 pm
its certainly more durable, and the temps are not as high as manifolds which tend to get ceramic coating on them if they want a nice finish
it would work on the rear box but at the down pipes where its hotter it may not last.
if yoy just want to preserve the system, it may be worth a shout. the down pipes on a 3 piece system can be left alone, they hardly ever fail.
looking on some bike forums, powder coat seems to have held out. there some powder coaters near pete who i've used
Post Wed Jan 26, 2011 11:32 pm
Its just the centre and rear boxes that i need done. The manifold and x pipe is stainless.
Kos
Post Wed Jan 26, 2011 11:34 pm
i'll get the number to you want ?
Post Wed Jan 26, 2011 11:50 pm
Ok mate, drop me a pm. Thanks.
m_jermyn
Post Wed Jan 26, 2011 11:57 pm
Used VHT exhaust paint before Barry and I have even used VHT brake caliper paint aswell on exhausts..
Just clean it and spray it on. The caliper paint has a ceramic look to it and it does look nice... I spayed all the silver bits on my engine in the silver caliper paint as it gets quite hot in there but nowhere near the 100 + deg calipers get.
The problem with powder coating is its quite easy to chip it, and if you want to touch it up its a rip out job. The VHT is just a spray can so its alot easier to maintain.
csl
Post Thu Jan 27, 2011 2:12 am
bss325i wrote:What sort of prep did you do? Did you prime it in any way or just use the VHT?
No i didnt primer it.I just thourghly cleaned the metal and then sprayed on a few coats of the stuff. :)
Post Sat Jan 29, 2011 8:23 pm
I went with some VHT in the end. Plenty of prep so we'll see how long it lasts.
csl
Post Mon Jan 31, 2011 12:48 am
bss325i wrote:I went with some VHT in the end. Plenty of prep so we'll see how long it lasts.
OK Barry,hope it does as well for yours as it did for mine. 8)
