mk1 golf gti OIL pressure sender location?URGENT
320Touring
Post Sat Jan 22, 2011 10:24 pm
i'm supposed to be going to see a mk 1 gti tomorrow for my mrs..
Seller called tonight reporting a 'pop' sound being made after the oil being topped up (to the 'full' line) and the car started..
Oil pressure light is on, and apparently oil coming out from above the filter.
I'm thinking its a dodgy sender that's popped-assumong there is a sender on the top of the filter?
Am i right??
HairyScreech
Post Sat Jan 22, 2011 10:31 pm
could be a poorly fitted or cheep filter has popped its rubber seal out, check that as well.
320Touring
Post Sat Jan 22, 2011 10:38 pm
cheers:)
Is the filter at the front of the block? Its been years since i've seen, let alone worked on one!
Post Sat Jan 22, 2011 10:40 pm
yeah the sensor is on top of the filter housing, should have a yellow wire going to it.
I'm sure that as well as a light coming on, a buzzer should sound for low oil pressure warning.
320Touring
Post Sat Jan 22, 2011 11:04 pm
hi lee, apparently the buzzer does sound.
The fact that oil squirts out when car is running suggests that the oil pump is ok?
I'm thinking oil is either leaking past the sender (split diaphram?) or as suggested above there's a leak from the filter.
Owner supposedly sending pic of area tomorrow morn before we head to see it (400mile round trip.)
Andyboy
Alpina Colada
Post Sun Jan 23, 2011 4:43 pm
The oil pump/filter hosuing/sensor set up on these engines is utter dogshit. The main issue is the pressure relief valve in the pump. They can stick open = no oil pressure, or stick closed - about 200 psi, oil pissing out everywhere and when it gets really high, it can even hold the hydraulic lifters open. The two switches (one for the light and one for the buzzer leak like a f*cked fridge anyway.
First thing I'd do with one of these turds is to drop the sump (very, very easy), wash it out and bang a new pump on - genuine would be nice.
brooklynballer
Post Sun Jan 23, 2011 5:55 pm
Maybe they put too much oil in it?
320Touring
Post Mon Jan 24, 2011 1:09 pm
Andyboy wrote:The oil pump/filter hosuing/sensor set up on these engines is utter dogshit. The main issue is the pressure relief valve in the pump. They can stick open = no oil pressure, or stick closed - about 200 psi, oil pissing out everywhere and when it gets really high, it can even hold the hydraulic lifters open. The two switches (one for the light and one for the buzzer leak like a f*cked fridge anyway.
Thanks Andy,
As soon as it arrives here thats the plan- bit of a fettle then she'll be good.
As for the oil level, it was only at max on the stick.
All good.
for the help people
