which temp gauge swich do you use? it has a round 4 pin one and had a black 2 pin, on the wire loom it says brown temp on the plug, the brown one's thread is too big to go into the engine
any thoughts or what you have used?
temp gauge m52
hongkongfuey
- Mad-tango-geezer
with cars like mine,
M20 temp plug Rob
hongkongfuey
- Mad-tango-geezer
yeah mines like that but the single pin (brown) wont fit? will blue do? it had a black 2 pin one in there which is broken
I don't know to be honest mate, I got my loom from Dan, so maybe he has grafed a M20 connector onto the loom.
Plug n play me like
Edit, are you saying the temp sensor won't screw into the head?
I just bought a new M20 one from the stealers and it went straight in.
Plug n play me like
hongkongfuey
- Mad-tango-geezer
sorry worded that wrong, mines a dan the loom too, thats not the prob, are you using the brown plug or blue?
craigieeb
Dont you have to "file" the threads down a bit for the temp switch to fit?
iirc
the threads are the same pitch,
but on the M20 sensor the threads stick out more/larger
so in order for it to fit, run a flat file over/round the thing
iirc
M50 Turbo!!!
I shall say no more
hongkongfuey
- Mad-tango-geezer
cool i'll try that then
shedrool83
hongkongfuey
- Mad-tango-geezer
the blue one fits, the brown doesnt?
It will need turning down and a new thread cut, the E30 sender is 14mm thread, the smaller hole in the M52 head is 12mm
Some of the earlier M52 heads (like Lees above) have two large 14mm holes and one 12mm
From the sounds of it yours has just the one 14mm and one 12mm
hongkongfuey
- Mad-tango-geezer
just had a look, and mine only has two holes the brown wont go into the right hand hole?
