Advice on bleeding brakes DONE!
jann
Fri Jan 21, 2011 2:57 pm
Hello
My brake fluid is very empty and is a gun metal charcoal colour.... I have stopped driving it for obvious reasons.
I would like to change the fluid by my self (keen to get down and dirty ha) and was wondering is there a step by step tutorial.
Also what fluid should I use (Dot 4)
How long do it usually take.
I've heard you have to bleed each corner in a specific pattern??
If worst comes to worst how much does a garage charge and I mean this is the last option lol.
The patient is a 91 IS (rear discs too)
Any answers who be great.
Jann
turk
Fri Jan 21, 2011 3:05 pm
S54, S62, S65 & S85 Plug & Play loom/Ecu Kits
Sump Baffles
Engine Conversion Kits/Parts
TrackDays
Fri Jan 21, 2011 4:00 pm
buy an easy bleed kit for about £20 and you can do them on your own without needing anyone to pump the brake pedal.
plugs on to your wheel valve and works under the psi of the tyre
8)
clipper
Fri Jan 21, 2011 4:21 pm
magpie wrote:buy an easy bleed kit for about £20 and you can do them on your own without needing anyone to pump the brake pedal.
8)
+1
I was advised on here to get one and it makes the job so much easier.
Just keep the pressure to the lower end of the specified range as I found that some fluid was blowing past the seals and spilling. No bother, just a waste of fluid and more cleaning up in the in-laws' garage required :mad:
Oh, and do your clutch fluid at the same time !
jann
Fri Jan 21, 2011 4:24 pm
I found this i don't one of those things above.
Is this the correct way. http://www.unofficialbmw.com/all/brakes ... fluid.html
Also how do you change the clutch fluid? 8O They use brake fluid right?
Jann
Fri Jan 21, 2011 7:18 pm
If the brake fluid reservoir was empty, then you have a leak to sort out before you do much else!
Clutch fluid is changed in exactly the same way as the brake fluid, but you only have the one bleed nipple to deal with, on the clutch slave cylinder.
jann
Fri Jan 21, 2011 8:22 pm
Well it was right at the bottom when i brought the car and i mean right at the bottom:/
So its just real low, It's done less than 7k in 3 and a half years so it needs a change.
What would you recommend? Pagid?
Its doesn't see the track so is the difference for DOT3 and DOT4 great for normal driving.
I'll treat him for his 20th next month with some new NGK's :)
Jann
jann
Sat Jan 22, 2011 11:14 am
Just quickly guys as im away without the care so i cannot check which fluid to get?
Any help.
Jann
Posted from iPhone.
richy187
Sat Jan 22, 2011 1:00 pm
DOT 4 is fine
jann
Sat Jan 22, 2011 3:33 pm
Come across a problem. on the second wheel i have started bleeding no more fluid is coming out, the pedal is soft after pumping (though is did go hard once) Im on the left rear. also the reservoir level is not going down.. Helpp.
jann.
richy187
Sat Jan 22, 2011 7:10 pm
Sounds like a blockage somewhere. :?
PG325
Sat Jan 22, 2011 7:18 pm
Try a small drill into the bleed nipple, sometimes crap builds up.
jann
Sat Jan 22, 2011 8:47 pm
Thing is also i did the right rear fine, pedal was hard then moved to the left rear. :/
jann
Sun Jan 23, 2011 3:40 pm
Finished the job myself, now clear fluid and a real hard pedal, stopping power is immense! Rears seem to be working too!
RESULT! saved myself a wod of cash too.
cheers
jann
P.s thanks guys for the tips.
