Mains
GUIDE-BEARING SHELL WHITE 11211706831
GUIDE-BEARING SHELL WHITE 11212241936
Bearing shell white 11211706849
Bearing shell white 11211717528
Rod
Bearing shell, red 11241404133
Little end, can you get them seperate?
Piston
Repair kit piston rings 85,965MM 11251402394
Snap ring x6 11251401807
Oil Pump
Oil pump 11411740154
ROTOR INNER 11411722905
ROTOR,OUTER 11411722907
Hex Bolt with washer x 4 7119915046
Waterpump
Rmfd water pump 11511406650
Gasket Asbestos Free 11511318287
O-ring 11531318402
Thermostat 11531318274
Head
Cylinder Head Gasket Asbestos-Free 1.74MM 11121405748
Gasket Asbestos Free 11121317364
Torx bolt (x14?) 11121317979
Bottom End
Gasket Steel 11141432240
Shaft seal 90X110X12 11142249533
Gasket Asbestos Free 11141318280
Gasket Asbestos Free 11141317289
Shaft seal 48X65X10 11142249532
Also need the mains bolts, but can't find the part number for them!
Prices please..
- Homo Hair
Cotswoldbmw
Hi There
Mains
GUIDE-BEARING SHELL WHITE 11211706831 £17.39
GUIDE-BEARING SHELL WHITE 11212241936 £17.39
Bearing shell white 11211706849 £10.37
Bearing shell white 11211717528 £10.37
Rod
Bearing shell, red 11241404133 £10.18
Little end, can you get them seperate? Vehicle details please
Piston
Repair kit piston rings 85,965MM 11251402394 £72.66
Snap ring x6 11251401807 £12.44 for 6
Oil Pump
Oil pump 11411740154 £254.71
ROTOR INNER 11411722905 £24.76
ROTOR,OUTER 11411722907 £9.55
Hex Bolt with washer x 4 7119915046 £1.18 for 4
Waterpump
Rmfd water pump 11511406650 £403.70 surchage credit of £73.39 on return of old unit
Gasket Asbestos Free 11511318287 £3.24
O-ring 11531318402 £2.51
Thermostat 11531318274 £26.83
Head
Cylinder Head Gasket Asbestos-Free 1.74MM 11121405748 £131.41
Gasket Asbestos Free 11121317364 £1.36
Torx bolt (x14?) 11121317979 £36.90
Bottom End
Gasket Steel 11141432240 £2.84
Shaft seal 90X110X12 11142249533 £34.21
Gasket Asbestos Free 11141318280 £7.67
Gasket Asbestos Free 11141317289 £2.39
Shaft seal 48X65X10 11142249532 £13.96
Also need the mains bolts, but can't find the part number for them! Details please
Prices inc. VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 53852
There is a P&P cost of £1.99 on all orders under £20
Brett
Mains
Rod
Piston
Oil Pump
Waterpump
Head
Bottom End
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
- Homo Hair
Details would be an e36 M3 3.0 1994... M567CBY
