only when hot
i was thinking either
clean the idle valve
or a split pipe
any other ideas?
hunting at idle
hongkongfuey
- Mad-tango-geezer
oxygen sensors, make sure throttle is closing, air filter/cone? blocked, temp sensor on the block
with cars like mine,
aaronsmart
had a look today actuly and a hugeeeeeeeeeee tear in the inlet pipe between the throttle body and air mad meter
it looks like it had been glued and torn open again, i must of missed the glue before!
