Auto ECU and harness
gudgeon
Post Thu Jan 06, 2011 12:09 pm
Just thinking ahead.
My M50 came out of an auto. The harness has an EGS connector that I was simply going to strip out.
The question is, is the ECU specifically an auto one? Are there any changes I need to make on the ECU or the EGS wiring (short a couple of pins or connect one to 12v) to make it work?
Thanks in advance
Jon
Post Thu Jan 06, 2011 2:01 pm
ECU is the same
gudgeon
Post Sat Jan 15, 2011 10:45 pm
So I'm happily chopping out the bits I don't need, starting with the EGS connector I've traced all the wires and cut out the bits I don't need.
The gearbox end had 3 connectors, what I'm uncertain of is why one of the connectors goes to a relay via a green/blue wire. What do I do with this wire If I no longer need the auto gearbox connector. A relay with only 3 wires in it doesn't feel right. How many relays should I have? I have 3.
Some help here would be welcome.
Post Sat Jan 15, 2011 10:48 pm
None of the auto box wiring is connected to a relay
gudgeon
Post Sat Jan 15, 2011 11:00 pm
Thanks Dan
What's the 4 pin screw connector thing down by the gearbox connectors?
Lambda possibly?
Post Sat Jan 15, 2011 11:05 pm
Yes, if its an M50 loom
gudgeon
Post Sat Jan 15, 2011 11:07 pm
Hmmm...
So Lambda connects to a relay, and also the ECU.
What if there's no Lambda? Is it like M20 Ecu and it just works around it in its programming if there's no lambda?
