abs light
- Brianmoooore
That depends very much whether your particular E30 has the relevant relay under the dash. It was only fitted on earlier ABS systems, up until sometime in '88 (that's a guess.)
What, EXACTLY, does the ABS light do, from the time you switch on the ignition until after you have driven away and up to speed?
