Rotor arm metal mount---11311713064.
Fan pulley washer x4---07119932099
Fan pulley bolt x4---07119913426.
Upper water hose---11531287651
Manifold support bracket bolt---M6X25
Rocker Cover nut x8---07129904858.
Rocker Cover stud x8---07129908103
Oil pan bolts x25---07119915031
Distributor cap---12111725070
Rotor---12111734110
Spark cable bracket ?---12121719889
Sorry if some of the nomenclature isn't exactly correct, I just used my own personal quickhand to remember what part(s) belonged to which part number(s)
Thanks!
---Kaleb
Engine bits needed
E30_Crazy
E30_Crazy
Anything? 10 looks, but no posts....
craigieeb
M50 Turbo!!!
I shall say no more
E30_Crazy
Anyone back yet?
E30_Crazy
bump
Cotswoldbmw
Hi There
Rotor arm metal mount---11311713064. £12.29
Fan pulley washer x4---07119932099 £0.78 for 4
Fan pulley bolt x4---07119913426. £0.96 for 4
Upper water hose---11531287651 £30.82
Rocker Cover nut x8---07129904858. £2.34 for 8
Rocker Cover stud x8---07129908103 £1.21 for 8
Oil pan bolts x25---07119915031 £3.78 for 25
Distributor cap---12111725070 £100.81
Rotor---12111734110 £21.71
Spark cable bracket ?---12121719889 £9.56
Prices inc. VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 53153
There is a P&P cost of £1.99 on all orders under £20
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
E30_Crazy
Just a quick one here... Is that the proper part number for the pre-facelift ('87) M20B25 coolant hose? The one I have now I believe is facelift, as it has to be bent/almost kinked and ziptied to the loop on the front of the cyl. head.
Cotswoldbmw
The hose you have listed is facelift 09/87 onwards
Brett
Brett
Cotswold BMW Parts
01242 335365
01242 335365
E30_Crazy
That's the part number from realoem. Do you know the poat number for the same hose but prefacelift?
