Manifold
HenryM3
This is a pic of the S50B32 manifold after modding thats on my car, hope it helps someone.
GeoffBob
- Forced Induction Specialist
Hmmmm, tastey. Nicely crafted
reggid
what are the primary and secondary ID?
E30 325is with M20B31
UweM3
most of that is S50 stock manifold. BMW didn't skimp for a change.GeoffBob wrote:Hmmmm, tastey. Nicely crafted
HenryM3
All of it is, 4 & 5 have become 5 & 6 and as you can see 4 is made up from another 5 and bits of the old 6 the very slight reshaping of the collector was to clear the ARB.
UweM3
you haven't got some bit's left by any chance? I would like to "turn" my No6 round.HenryM3 wrote:All of it is, 4 & 5 have become 5 & 6 and as you can see 4 is made up from another 5 and bits of the old 6 the very slight reshaping of the collector was to clear the ARB.
Have you done it yourself?
HenryM3
As you can see No4 has a couple of sleeves, I got a bit of stainless tubing and cut those sleeves off it and made up the shape from bits I got of Ian, to get it right I had a piece of metal drilled to match the stud pattern on the head then I was able to bolt the manifold to it so that when I was pissing about with No4 everything else was solid. The collector box for 123 I cut and filed to get the shape I wanted and believe it or not I held them together with cable ties and took it along to the guy who welded it. If only I could weld like that. I have some bits in the shed, I'll look tomorrow but I don't think there's anywhere near enough to do another pipe. I'll let you know one way or the other.
UweM3
cheers boss.HenryM3 wrote:As you can see No4 has a couple of sleeves, I got a bit of stainless tubing and cut those sleeves off it and made up the shape from bits I got of Ian, to get it right I had a piece of metal drilled to match the stud pattern on the head then I was able to bolt the manifold to it so that when I was pissing about with No4 everything else was solid. The collector box for 123 I cut and filed to get the shape I wanted and believe it or not I held them together with cable ties and took it along to the guy who welded it. If only I could weld like that. I have some bits in the shed, I'll look tomorrow but I don't think there's anywhere near enough to do another pipe. I'll let you know one way or the other.
I only need one pipe with the flange. The rest will be doable more or less. Just want the No6 to point in the same direction as No5. And having LHD helps a lot. I don't need to make any changes to 1-2-3
HenryM3
This is what I have been able to dig out, if any or all of it is of interest to you let me know and I'll get it off to you.
UweM3
PERFECT! That will be a great help. Going to PM youHenryM3 wrote:This is what I have been able to dig out, if any or all of it is of interest to you let me know and I'll get it off to you.
HenryM3
sorry about the delay Uwe, by the time I had parceled it the Zone had gone down and I couldn't retrieve your address, it will be posted in the morning
UweM3
no rush, please take your time. I won't round working with the manifold soon anyway.HenryM3 wrote:sorry about the delay Uwe, by the time I had parceled it the Zone had gone down and I couldn't retrieve your address, it will be posted in the morning
Engine mounts need to be done first.
