wet carpet passanger side rear
woodysjw
Can anyone tell me why this is wet and where the water could be comming from
796 - 1989 Motorsport Edition
dobbie82
- Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
sunroof?... door/window seals?
sorry just a little post whore really but bumping your message all the same.
Heater valve, rust holes?
Do a taste test to see if it is coolant.
dippae30
the notorious rear arch rust?
Just noticed OP says rear!
There's two big round metal plugs in the rear floor pan; one each side.
These come loose or rust and let water in.
Depending on what state they are in, they can be refitted and sealed, or remove them completely and weld plates over the holes.
dazleeds
- old skool raver
lift passenger side rear carpet there should be a round plate in floor has the seal failed???
very common in my experience and soaks the rear just 1 more for ya too check as well as all above Daz
www.oldskoolfantasy.co.uk
