injectors
e30-ian
Sat Dec 11, 2010 11:10 pm
Ive heard alot about rebuilding the injectors? is there any signs to look out for i.e missfireing? or is it just part of a healthy service, my 325 does have a missfire when cold and stinks bad of fuel but not sure if having the injectors done will help with anything, i replaced the blue temp switch (bmw) secondhand AFM but was told i have to have it reset?? changed the plugs and leads, timing set up right. now im just wondering about injectors ?
mrb27
Sat Dec 11, 2010 11:21 pm
well with the afm its not so much a reset, more an adjustment if needed for the emissions, as for the injectors, its said that as little as 20k miles on them they will start to weaken and get a little grubby. my old m20 on idle would lump a bit and when driving at a steady rpm would jerk a little, new set of recon injectors and it ran so sweet, any second hand car i buy in the future is gonna get a new set of injectors instantly!! i have a set on the way right now for my 2.7, they make such a big differance :D
e30-ian
Sun Dec 12, 2010 7:16 am
how much would this cost ?
Sun Dec 12, 2010 9:32 am
£10 each.
e30-ian
Sun Dec 12, 2010 4:36 pm
cheap, is there anyone you can put me in touch with thats around cheshire ?
charlE30
Sun Dec 12, 2010 5:01 pm
The guys you want offer the service via mail order and are on here in the traders section, look for injectortune :D
http://www.e30zone.net/modules.php?name ... c&t=152878
BMW F31 335d xdrive
N00b
Sun Dec 12, 2010 7:44 pm
e30-ian wrote:cheap, is there anyone you can put me in touch with thats around cheshire ?
You get a report back with your injectors, showing their flow characteristics before and after cleaning.
