squeeks and rattles
William
Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
Post Fri Sep 30, 2005 7:45 pm
I know this an overdiscussed topic, but i'll ask anyway. I just put my hardtop on my cab and on smooth roads the cabin is lovely and quiet and you can hardly tell your doing 80 or whatever. But on rougher roads there are continues noises coming from the back which I can't locate from the driving seat. They are mostly rattles and squeeks, does anyone know of obvious things I can check/get someone else to check??
thanks
:thumb:
Globulator
Post Fri Sep 30, 2005 11:19 pm
Go to a diving store and get some silicone grease. Smear tiny amounts on every rubber surface that touches glass - even the edges (where all my noise came from).
Other than that make sure the hood is stowed well and the cover catch isn't buzzing - you might need to bung in a rubber rest to tension it.
Get someone in the back to listen while you drive - or vice versa if you trust them - and see if there are any more to find.
Good luck.
William
Post Sat Oct 01, 2005 8:03 pm
thanks mate will try that. Sounds I can hear were there when the soft was up so I don't know if that points to exhuast brackets (do they squeek??) or something internal at the rear (does suspension squeek or rattle or just knock when it gets knackered?
:thumb:
MONSPORT42
Post Sat Oct 01, 2005 9:04 pm
Check out the suspension top mounts - rubbers can go and rattle a bit.
YOUR LEFT FOOT'S FOR BRAKING
Ziggy
Post Sun Oct 02, 2005 12:39 am
Globulator wrote:Go to a diving store and get some silicone grease.
Not sure I know of any of those! Anywhere else you can get it?
M5pilot
Post Sun Oct 02, 2005 11:06 am
Top mounts make alot of noise if they are worn out.
Globulator
Post Sun Oct 02, 2005 11:43 am
I used the new fangled internet to get mine ;)
http://www.google.co.uk/search?q=diving ... one+grease
I think my little tin came from somewhere in cornwall actually.
BTW: Silicone grease was called Gummifledge by BMW when they used to sell it. Now they just don't sell it. It's also used sometimes for brake rubbers so a motorstore might just sell it - you never know.
Post Sun Oct 02, 2005 1:14 pm
Plumbers' merchants. Used for lubricating the O rings in soil pipes.
Cabrio
Post Fri Oct 07, 2005 10:19 pm
Hi
Automotive vaseline is what you can use on the hardtop seal and front window frame etc
Can bring some to Donnington if you are going..or show you
whether an original or Wiesmann roof may need adjustment...if original to adjust properly will need proper spanner aswell as you 11mm...but better to borrow than buy as you should only need it the once
iil325i
Post Fri Oct 07, 2005 10:27 pm
i got told by some1 with a e36 that they whent 2 there bmw dealler and got a tool 2 clomp it down and that grees stuff
http://img19.imageshack.us/img19/7697/picture0232nn.jpg
