can any1 advise?
e30 327i cab help required!!
SHAK
Driverside window goes up but when theres about an inch left it starts to bounce???
can any1 advise?
can any1 advise?
Jimbob
I'd say this was a technical question, wouldn't you?
Please use the correct areas.
I don't know what the problem is mate, but you will find out a lot more if you take the panel off so you can see what the mechanism is upto fella.
Sounds like one of the early rack type mechanisms. If it is, I think you've found why the mechanism was changed to a completely different type.
