tweeter wiring in convertible?
d1mkaz
Post Thu Nov 18, 2010 2:06 pm
is there any wiring in 1989 convertibles doors for tweeters, thinking of installing in side mirrors inside panels, but not sure about wires. which ones I have to look for. thanks
Post Thu Nov 18, 2010 4:33 pm
yes, there green/grey and yellow/grey
Post Thu Nov 18, 2010 9:05 pm
Should be but just remove the triangle things and check :)
I've heard that the wire colour tends to change when it comes out of the door wiring plug :?
d1mkaz
Post Fri Nov 19, 2010 8:35 am
thanks, will check :)
d1mkaz
Post Sat Nov 20, 2010 2:44 pm
Alex wrote:yes, there green/grey and yellow/grey
ok, the left side here
and right side (rust found :eek: ) here
as you mentioned the colors are green/grey and yellow/grey ,
I did not check the door wiring plug yet, but will the colors be the same or as Imys said they can change? how to find the ones I need? where they suppose to go after door plug?
