instrument cluster lights, rear lights and indicator issues
95-540iLE
Zone Newbie
Thu Nov 11, 2010 10:05 am
Had some time tonight to look into the fact only half of my instrument cluster lights up and also to examine the cogs on my now defunct odometer.
After pulling it out and replacing the bulbs, I refitted the cluster temporarily to see if the cluster lights now worked. But got nothing, not even the half that was illuminating.
I played around for a while refitting original bulbs but cant get any illumination now.
Also, the left indicator now blinks about twice as fast, the rear normal lights aren;t working and the rear passenger indicator isnt either.
Any ideas what i have done and how I can fix it? An examination of the fuses doesn't appear to expose any blown ones!?
1985 Hartge H23 (now sold)
1995 M540i (Aust version) - #62/70 & 49/70
2005 Holden Calais - 5.7L V8
2009 Ford Falcon XR6 Turbo (times 2)
**BANNED**
Thu Nov 11, 2010 10:14 am
Is your indicator stalk in the central(off)position?
Is the dimmer control on the main light switch turned fully clockwise?
Youth is wasted on the young.
95-540iLE
Zone Newbie
Thu Nov 11, 2010 10:18 am
Indicator only on when in turn left position then blinks very fast. Blinks normally for turn right.
And yes, I tried the dimmer control.
TouringTash
Thu Nov 11, 2010 10:21 am
Sorry if this is basic stuff but when indicating left do all the bulbs indicating left work? A faster flash normally means a blown bulb. As for the rest of the lighting issues it sounds as if a wire or three are trapped.
318i Touring
**BANNED**
Thu Nov 11, 2010 10:27 am
So the l/h rear indicator is not strutting it's stuff?
As the tash suggests,could be the bulb there or a loose wire at the column switch end.
Regarding the cluster,both plugs in correctly and all wires attached?
