Is a an E34 530i suitable for V8 conversion?
sajad09
Post Tue Nov 02, 2010 6:36 am
I have the opertunity to buy a E34 530i manual. i am keen on doing a v8 conversion to my E30 in a few weeks. i have read many threads on the zone, but wonder weather its worth holding out for a 540i donar car, or is it possible to do a 3.0 conversion and then maybe buying a 4.0 engine as one comes along in the future? i am not even sure if the 530i gearbox will be usable with 4.0 engine? help needed please as i have to let the guy know if im buying the car or not, asap. it is cheap and manual, so i dont know what to do.. any sugestions would help. thanks. :)
glenn
Engine Transplant Services
Post Tue Nov 02, 2010 5:20 pm
it all depends on how much your paying for the doner?
the power output of the 3.0 engine isn't worth the hassle of the conversion.
but you could do it with the 3.0 with the view of ripping it out once you've found the 4.0.
stbaz
Post Tue Nov 02, 2010 5:57 pm
thats what i planned to do, i had the 3.0 more or less fully fitted then decided bigger was better.
i have the 3.0v8 manual flywheel and clutch on the bigger engine with the 3.0v8 5 speed box
FormerMember
Post Tue Nov 02, 2010 7:48 pm
Buy it if it's cheap, it has basically almost all you need to do the conversion properly (excluding the engine). As the swap will take couple of months you'll have plenty of time to search for B40 engine which is direct bolt-on in place of the 3-liter..
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
sajad09
Post Wed Nov 03, 2010 2:21 am
thanks guys deal done, ill be picking it up on the weekend. finaly the ball is rolling!! been looking for a doner car for ages.. :D
vikman
Post Sun Nov 07, 2010 2:06 pm
yes. its direktly to bolt on the 4,0 engin indsted 3,0 v8 engin. But yom must remember that cluch from 3,0 is't as strong as from 4,0l. Så I will by a stronger cluch kit.
