Dash Batteries in The E30
T-roy
Fri Oct 22, 2010 12:41 am
Guys,
I am about to change the Batteries in My E30 cluster. It is out and all apart, it has the old Rechargable AA type. I i am doing this because the temp gauge is not working and also the econogage is playing silly buggers. the car has been sitting for sometime about 10 months.
I have a couple of questions.
1. when i replace them will they need to be charged before soldering in or do the E30's have some sort or recharging setup if so how can i check this is working.
2. will the batteries be affected by the heat of the soldering in.
3. i have seen a few guys nount these outside the cluster for easy access, is there much involved.
4. can they be replaced with the newer Lithium type setup.
Cheers.
Troy
DaveD
E30Zone Wiki Specialist
Fri Oct 22, 2010 8:56 am
tbmw recommended a couple or three years ago
M a p l i n 0870 2646000
1050mAh NiCd batteries £4.98 per pair
Maplin Re f e r e n c e V N 3 9 N
and this thread tells all
http://www.e30zone.net/modules.php?name ... ht=battery
