Car wont start, fuel pump?
Ok right at this minute I'm stranded in town. Power to car and car clicks when try to turn it over.
I don't hear the fuel pump when ignition goes on, the car wasn't running properly last night sounded as if it was misfiring, maybe not enough fuel coz pump was failing.
What test can I do to make sure it isn't wiring relays etc before I buy a pump?
This car has been off road for last 6 months and only got it onthe road last night lol
Thanks guys
Thanks guys
Parts Wanted:-
Tech 1 Side Skirts,
Borbet B Alloys or Borbet A Alloys, Electric Sunroof Motor Cover,
Opening Rear Quarters
Tech 1 Side Skirts,
helmi25cab
take the back seat up and the small black panel, put your hand on the fuel pump, if it works you'll feel it, just recently had to change mine. people say you can hear it but i cant hear it (and no i'm not 75 )
i could always hear mine, i took the cover off, turn it over and nothing,
it could be a fail wire or something, not sure where to look,
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
how do i test the fuel pump gets a 12v feed so i know it isnt wiring? i have a multi meter, which wires do i need to touch
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
also i have the e36 318is engine, which fuel do i need, e30 318is pump or e36 318is pump?
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
helmi25cab
To check the fuel pump, first check fuse 11 is OK, then pull out the fuel pump relay and link together pins 30 and 87 of its base. This should make it run continuously, even without the ignition switch being on, and will easily be heard (if it's OK), without the noise of the engine masking it.
the battery was used in my golf for 5 months, then i put it back in the e30.
I might go see if i can jump start it from my dads car, but im pretty sure battery is ok, but it would rule that problem out i guess
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
helmi25cab
tap it few times i guese, dont smash it!!!!!
helmi25cab
i know you probaly wanna do that right now!!!..................... lol
ok i have tapped it a number of times, nothing,
the battery is reading 12.53 volts.
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
cant push it fast enough to bump start, run out of room, i live on main road too,
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
ok, i bypased all the electrics, took jump lead from + on battery connected to start motor and the motor spun, only did this for 2 seconds
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
