Hi All,
I've just completed a coilover conversion on my front struts, however due to the 2.25" the old bumpstops clearly aren't going to fit.
What bump stops are recommended / available for front coilovers?
If it helps I'm using KW dampers.
Any links or recommendations are welcome.
Coilover Bumpstops
oldroydsr4
Anyone?
MillRat
Don't the KW coilovers come with their own bump stops?
I run V2's in my E30 and I am sure it had bump stops. If not, can you cut the old stops to fit?
Cheers,
Michael.
gareth
oldroydsr4
Thanks for the replys. I've made my own coilovers with kw dampers.
I'll go with those from rally design should be good for the job.
UweM3
powerflex sell some aswell.
Do you need them for front or rear?
oldroydsr4
front,
