I have spent money on usual maintenence but to be fair i only needed have done the cambelt/waterpump. Its on about 123k and i am the third owner. The first owner had it until 2005/110k, and had full service history till then with regular bills of £400+ at the dealers. I dont have any history from the second owner other than a couple of mots, but he only did 6k in it anyway.
Stuff i have chosen to do so far:
Added 15"bbs within about 2 weeks
Smoked indicators
New numberplates [not horrible german lookin stuff!]
Oil cooler grille
Plugs, air filter, oil and filter change
More recently diff oil, gearbox oil and fuel filter
Speedtouch mild chip
Heres a few pics
I can hear you all sayin lower it but i dont mind how the car sits. But sadly the suspension is all original. This is great for cruising but when pushing the car it is rubbish. I have bought some 318is/mtech springs just to drop it 20mm and tighten up the handling. Can i use original dampers or do you think boge turbo or billstein b4 would be worth adding? And would you bother with rear dampers or just the fronts?
Styling wise i will not be doing much just making perfect the paint/bodywork and maybe se skirts and an is lip.
Other plans are
325i throttle body on opened out manifold, which is practically ready to bolt on
Rotor arm/dizzy/leads
Rear anti roll bar and maybe strut brace
