For the People that have fitted Angel Eyes
Gouki
Post Thu Sep 22, 2005 11:19 pm
alright need a bit of help, i've fitted the new lamps in there's some sort of wiring harness plu with 2 pins which I'm stumped with, i connected everything else my angel eyes dont work, now has anyone had a problem with fitting them before, btw they are the Depo ones.
smithy318i
Post Thu Sep 22, 2005 11:33 pm
Im confused. which wire?
One end plugs into the sidelights, the relay plugs into the socket, the two other ends go to the lights and you have a Gnd and a positive wire.
it doesnt get any more simple matey.
Gouki
Post Fri Sep 23, 2005 5:49 pm
i'm gonna take a pic of the wiring diagram and the pic of the plug that seems to go no where!
TW166Y
Post Fri Sep 23, 2005 6:14 pm
think it depends on what model your cars is .ie pre face lift or not etc... im pretty sure that you need to "adapt" it to make it fit one or the other mate, put a piccy up thow and lets see. :wink:
Saying goodbye to 4-pot wrongness
Gouki
Post Fri Sep 23, 2005 11:33 pm
taken off my phone, this is the instructions,
it refers to a wiring plug harness "to the postion light of car body harness" this is the plug that don't seem to fit anywhere, pictured below:
After much thinking about it fustrated I decided to wire them my own way so now I can operate the Angel Eyes directly from a switch inside without turning the inginition on or headlights, see pic:
But having said that I do want to fit them properly if I can so any ideas about that plug I'm refering to because I connected everything else in the diagram correctly!
smithy318i
Post Fri Sep 23, 2005 11:47 pm
That goes to one of the sidelight wires.
