what engine is this ??
TW166Y
Post Thu Sep 22, 2005 1:32 am
just wondering if this was a 325 and "not" a 320, it looks nothing like my engine and mine is a 325?? to mee it seems a lot smaller, the only thing that makes me thin it is a 325 is because there is no battery there, thinking of buying it but i just wanna be sure its what i want 1st! not too clued up with the engine side of things so any help would be magic, cheers ppl! :wink:
Saying goodbye to 4-pot wrongness
Mops
Post Thu Sep 22, 2005 2:32 am
pic is too small, i cant see a thing there.
one thing i noticed that the expansion tank is on the other side comparing to my 325i, but i never seen m20b20 engine, so i'm not too sure...
Look below the intake mainfold, you should find some numbers casted in the engine block....
first two digits are the displacment....
so if it says 20XXXXXX then it's a 2 liter m20b20
if it's 25XXXXXXXX it's 2.5 liter m20b25
Aswell, there should be metal "sticker" somnewhere under the bonnet (on my 325i it's abouve the RHS headlamp), what should tell you the exact engine cc and other usefull info (like max gross weight, etc)..
hope that helps :)
buster
Post Thu Sep 22, 2005 8:14 am
I'd say it was a 2.5 but without seeing it in person it could be a 2.0 with a 2.5 manifold !
Probably a 2.5ltr though.
Adammcf
Post Thu Sep 22, 2005 8:48 am
Sorry to butt in here but the numbers on my block below the inlet are:
1289575 29c89
What does this mean? Is the first part the engine number just?
Post Thu Sep 22, 2005 9:14 am
Apart from the air intake set up, that looks like the underbonnet view of an ordinary 325 to me.
Stick the VIN into an ETK.
jmc330i
Post Thu Sep 22, 2005 9:29 am
If it looks different to your 325i engine than maybe it was a 325i (hence the battery in the boot) but someone is trying to pull a fast one and has fitted a 320i motor.
On the exhaust side of the cylinder head just above the exhaust manifold, between the sparks for cylinders 1 and 2 will be a small round circle with 2.5 2.7 cast into it, if its a 2.5ltr.
Mops wrote: one thing i noticed that the expansion tank is on the other side comparing to my 325i, but i never seen m20b20 engine, so i'm not too sure...
All the face lift cars had the expansion tank behind the nearside headlight, the pre face lift have them on the driverside.
James
'91 325i Sport
'93 318i touring 16v
Hyperion
Post Thu Sep 22, 2005 9:46 am
jmc330i wrote: All the face lift cars had the expansion tank behind the nearside headlight, the pre face lift have them on the driverside.
thats interesting, over here, we never got the expansion tank. just the normal big ass one. :)
elliot
Post Thu Sep 22, 2005 9:47 am
jmc330i wrote:If it looks different to your 325i engine than maybe it was a 325i (hence the battery in the boot) but someone is trying to pull a fast one and has fitted a 320i motor.
although mine isnt a facelift car being a cab, mine does come in that era and my expansion is on the passenger side, how confusing :mad:
jmc330i
Post Thu Sep 22, 2005 10:53 am
I could be wrong then?? :?
Just from the 'early' and 'late' cars Ive seen, it seems to the case.
Mind you, Cabs are always a little strange :surrender: :lol:
James
'91 325i Sport
Simon
Post Thu Sep 22, 2005 11:00 am
Your cab looks like a facelift car though, it's got facelift headlamps.
James is right though, pre-facelift drivers side, and facelift on the passenger side.
