hi guys,i was on the m/way 2day and the coolant light came on,
pulled onto hard shoulder,water/steam everywhere,waited 20 mins then put in a litre of water i carry in boot,drove on to the next turn off but the traffic was hellish and the car started making grinding noises from the engine!anyway,2 cut a long story short,it was a burst hose which ive fixed,but will there be any damage to the engine?car seems ok now,but the noise was metal on metal!!
engine fu#ked?
Jamesb318is
Possibly the water pump let go (metal grinding noise) causing the system to overheat and pop the hose?
If not, just fix the leak, go for a gentle drive, monitor the temp and noises etc, and if nothing can be heard - all good!
Dan318-is
does it only overheat at operating temp?
mine does this still
no grinding noise luckily
