M52 power, with no power steering
craigieeb
Tue Sep 07, 2010 12:30 am
Looking at the 2.8 i'v just got,
it seems that the power steering pump runs off the same belt as the alternator,
i dont have power steering, and dont want it, i like a more direct feel thru the steering,
so....
can i get a smaller belt that still runs the alt,
but allows me to remove the power steering pump ?
or do i just disconnect the pipes and leave the pump in situ spinning/but not working ?
Tue Sep 07, 2010 12:34 am
Remove the pump, run a piece of string around the pullies to get the length which you can use to order a belt with from most motor parts
craigieeb
Tue Sep 07, 2010 12:37 am
Mint, cheers, should of thought of that really tho :mad:
another item on the list.........
Cheers Dan :thumb:
