Bought a cylinder head a while back and am finally getting round to preparing it to put it on the car (well, someone else will!).
But I want to clean it of the crud (oil etc) that has built up around the valves on the underside of the cylinder.
Any advice on this chaps? Or should I just send it away for an acid clean (is that right?) or something.
I'm having it stripped shortly for the pressure test.
I'm on a tight budget but anything I should do before they put the cams back on and valve train. Replace particular parts etc?
Any help gratefully recieved. The Savaloy.
cleaning a cylinder head.....
oi_oi_savaloy
m_jermyn
I cleaned mine with a mixture of degreaser and Kerosene 50/50... Came up pretty clean... I then got the head rebuilt and while he was at it I had him chemical clean it.... Came up like new...
I asked him what they use and he said its like a watery paint stripper, it did smell like paint stripper..
So when cleaning my inlet manifold I tried some paint stripper.... It cleaned off everything even the crusted on crap that I couldnt even get off with a wire wheel..
You can even get paint stripper in a rattle can..
Try paint stripper it works.
Mike
Mike
charlE30
Might give that a go myselfm_jermyn wrote:I cleaned mine with a mixture of degreaser and Kerosene 50/50... Came up pretty clean... I then got the head rebuilt and while he was at it I had him chemical clean it.... Came up like new...
Mike
I've just done one using an engine degreaser called 'Gunk' available from halfords and the likes. Give it a good soak then scrub with a stiff nylon brush and jet wash off... comes up quite well but does require a bit of effort.
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
